Marks on cylinder wall, valves too big?
Old 12-07-2012, 04:38 PM
Ferocity02's Avatar
Default Marks on cylinder wall, valves too big?
Pulled apart the engine yesterday to investigate a tapping noise that's been annoying me for awhile now. On cylinders 5 and 7, at the very top, there is a mark/groove that's been worn into the cylinder wall. It looks almost like the exhaust valve was touching it, but the valves didn't have any visible wear. The motor is a stock bore 5.3L, with 799 heads. The intake valves are 2.00", and it had six 1.59" exhaust valves and two 1.55" exhaust valves because they jackass I bought them from put in the wrong valves. I don't think these valves are too big for the cylinder though. NONE of the other cylinders have this mark, just 5 and 7. Luckily, the mark is just above where the rings get to so I hope there is no ring damage. Cylinder walls look money.
On first start up there was a screeching/tapping sound that started after about 5 minutes, and only lasted on for the first drive. Then a tapping noise began a hundred miles later or so that sounded like a lifter, hence the tear down I'm doing right now.
#7:
#5:
Old 12-07-2012, 06:11 PM
Ferocity02's Avatar
The groove isn't very deep, I could barely feel it with my fingernail. I'd guess its only a few thousandths deep. I took a file to lightly work the raised area down, should work out.
So are 2.00 and 1.59" valves too big for a 5.3L?
Old 12-07-2012, 08:56 PM
farmington's Avatar
how far bove the ring travel is the mark? If you have some room, I'd almost (carefully) touch the mark with a grinder so the valve won't touch anymore. Even .020 clearance would be good.
Old 12-07-2012, 09:55 PM
Ferocity02's Avatar
Well, the valves were the wrong size, 1.59 instead of 1.55. Once I get the right valves in there it should be fine. But I didn't know 2.00 and 1.59 were too big for 5.3l bore. And its weird that only these two cylinders had marks. Perhaps its due to minute errors in casting tolerance and mahining tolerance.
Old 12-08-2012, 10:31 AM
KCS
Moderator
KCS's Avatar
It looks like its just the exhaust valve that's too big. Are those the same two cylinders that had the LS3 exhaust valves?
Old 12-08-2012, 12:09 PM
Ferocity02's Avatar
6 of the 8 exhaust valves were ls3, but only thesee two have marks. Strange
Old 12-08-2012, 06:37 PM
ls1 1990 VN's Avatar
Well at least you found your tapping,
Quick Reply: Marks on cylinder wall, valves too big?
