9" with 3 channel ABS.
Planning on swapping out my Moser 12 bolt to a fabricated 9" with the new strange HD aluminium case and spool. As I still occasionally use it on the street, what needs to be done to retain 3 channel ABS.
LS1Tech Premium Sponsor
I can send the 3ch setup out in a retrofit kit if you have a 9" rear that was not originally equipped with it or are changing diff units that has the reluctor ring permanently attached.
If you order a MWC 9" package we will install it and set the air gap for you so it is a plug-and play option.
