VNT turbos?
Old 12-11-2012, 01:50 PM
91FormulaKiller's Avatar
Default VNT turbos?
Anybody messed around with VNT Turbos? Like a Garrett GT3782VA? (Powerstroke Diesel 6.0)
Curious... Reading about making 14psi @ 2000 rpms and as high as 28psi @ 3K+
Thoughts/Opinions?
Jay
Old 12-11-2012, 05:27 PM
dmaxvaz's Avatar
Too small of a turbo for ls engines. They make a **** ton of back pressure, and were designed with lower rpms /pressure ratios
Old 12-11-2012, 07:22 PM
Really? i believe the one i was checking out at work was an 88mm .9 a/r... saw a couple guys installing on 4.2L TB engines...?
Old 12-11-2012, 07:32 PM
DavidPHumes's Avatar
With how cheap budget turbos have gotten, it isn't worth cobbling together a setup based from an OEM turbo IMO. It will be in all ways less than ideal. Also keep in mind a turbo like that wasn't designed for a performance application.
Old 12-11-2012, 07:36 PM
I can level with that, just wanted to ask! thanks
Old 12-11-2012, 08:11 PM
LT1 ANDY's Avatar
Not to mention the controller/computer you'd need to control the turbine vanes!
Andy
Quick Reply: VNT turbos?
