LS7 Rockers ???
Old 12-17-2012, 06:46 AM
White Catfish's Avatar
Default LS7 Rockers ???
Are LS7 rocker arms direct replacement for LS1/LS2 rocker arms?
Old 12-17-2012, 06:54 AM
davidws6's Avatar
No, ls7 are 1.8 and the intake is offset.
Ls1 and 2 are the same. L3 are also offset.
Old 12-17-2012, 07:07 AM
Ok...Thanks for the info
Old 12-17-2012, 09:10 AM
DietCoke's Avatar
LS7 exhaust rockers are direct swap for ls1/2 rockers. They are 1.8 ratio instead of 1.7, but that is the only functional difference. They have a better tip profile for higher lift cams.
Old 12-24-2012, 02:53 PM
NemesisC5's Avatar
In...
Old 12-28-2012, 09:02 PM
Gray86hatch's Avatar
a ls7 rocker will hang .110" past the valve tip when installed on a non ls7 head.
the center of the trunion to the tip of the rocker is .110" longer on a ls7 exh rocker than a ls2 exh rocker
Tim
Quick Reply: LS7 Rockers ???
