replacing iron 6.0 heads with stock lm7 heads - worth it?
Old 12-20-2012, 06:56 PM
1988montecarloss's Avatar
Default replacing iron 6.0 heads with stock lm7 heads - worth it?
so i have an iron headed 6.0 that i plan on putting in my 88 monte and i just bought a complete 2000 lm7 for $200 and i was wondering if it would be worth it to replace the iron 6.0 heads with the 5.3 heads or not. i know ill need new headgaskets and headbolts so thats why i was wondering, would the difference in power be worth spending money on hg's/head bolts?
im just not really sure how well the iron heads flow compared to 317's (which i had a set of until a week before i bought the 6.0 )
Old 12-21-2012, 12:05 AM
LilJohn's Avatar
Ill buy the Iron heads if you decide to switch em out.
Old 12-21-2012, 12:09 AM
EDIT: found what i was looking for that i couldnt find before i made the thread, i guess 5.3 heads are a no go
liljohn you have a PM
Old 12-21-2012, 12:11 AM
bww3588's Avatar
Smaller combustion chamber and aluminum should be an improvement, but the smaller valves of the 862's will hurt it. It would probably be a wash unless you plan on running a compression ratio that the iron heads will limit.
Old 12-21-2012, 12:16 AM
yeah i guess ill just try to sell both sets and find a set of 317/243/799's
Quick Reply: replacing iron 6.0 heads with stock lm7 heads - worth it?
