Rear brake piston
Old 12-23-2012, 03:06 AM
AmnSF's Avatar
Default Rear brake piston
In the process of replacing my pads and when I tried to compress the piston it WOULD NOT budge and it still won't I checked to see if the piston had come all the way out and could access the snap ring and possibly rotate and push in little by little. No luck. Don't have a c clamp and no other vehicle to get one. WTF can I do to get the piston to compress?
Old 12-23-2012, 10:03 AM
AmnSF's Avatar
Problem solved. Disconnected the brake line and dumped the fluid in the caliper, compressed, and moved on.
Quick Reply: Rear brake piston
