HS turbo kit with alternator relocation???
anyone running this setup?
Just a stock crank pulley and bmr alt. relocation bracket using a stock alternator?
Does the kit still function properly and clear everything?
Or will I have to run stock accessory drives with water pump and all?
I would like to run my electric water pump and use my bmr kit for the alt.
thanks
If you have them post em
thanks
LS1Tech Sponsor
I don't see why it wouldn't work. Nothing in the kit is in the way of any of the accessories, just have to remove the AC and move the Alt up top to clear the truck manifolds. Less should be much more simple
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
