NEED Odometer Help
NEED Odometer Help
hi Im Darrell.A i live in California ,the bay area. I have a 1999 chevy Camaro 3.8 i unplug the battery and change the Maf the speedometer went out can someone help me!. not sure if this is where i post this ( the speedometer is laying all the way to the right pass 100 thank all
I wouldn't buy a new cluster without at least checking/ trying a few things first. Try this first: https://ls1tech.com/forums/general-m...g-battery.html If that doesn't fix it, the next thing I would check are the fuses (located on the drivers side of the dash.) If all the fuses look good, check and make sure your VSS didn't come unplugged and is making a good connection.
