853 head cc's question
Old 12-29-2012, 07:29 AM
farmington's Avatar
Default 853 head cc's question
Just picked up a nice set of ported 853 heads. They have been milled, the chambers are now 64.5cc. Anybody know what a bone stock set of 853's cc's at? Trying to figure out how much was taken off of the bottom of these so I can decide what gaskets/pushrods I will need. Thanks.
Old 12-29-2012, 07:48 AM
KCS
Moderator
KCS's Avatar
They should be around 66cc stock, but if the head has larger valves or looks like there was some grinding/blending done, you can't determine how much was milled based off the new chamber volume. For example, when I put 2.02"/1.60" valves in my 241 heads and blended in the top cut, I ended up with 68cc chambers.
Old 12-29-2012, 10:11 AM
farmington's Avatar
thanks, these have 2.02 1.58 valves and it looks like the chambers have been touched slightly. your info helps.
Quick Reply: 853 head cc's question
