Wheel Studs
Old 12-29-2012, 04:11 PM
AmnSF's Avatar
Default Wheel Studs
Did a search and nothing came back. If this is not in the correct section, feel free to move the thread. The stock wheel stud size for 93-02 Camaro/Trans Am's is 12mm correct?
Old 12-29-2012, 04:27 PM
RikkiTorment's Avatar
I believe you are correct at 12mm. ARP probably makes the most trusted wheel stud you can buy...
Here is a link to TSP's page:
http://texas-speed.com/p-257-arp-12m...eel-studs.aspx
Old 12-29-2012, 10:51 PM
94Z28-MSTGKLR's Avatar
What is the stock length?
Old 12-30-2012, 01:36 AM
I believe stock length is 41.5mm which is like 1.65 inches.
Old 01-03-2013, 11:55 AM
sjsingle1's Avatar
does ARP make a stock length stud?
Old 01-03-2013, 12:39 PM
Not entirely positive. I haven't looked for ones that are stock length as I was going to use a spacer/adapter for rims with a slightly different lug pattern.
Old 01-03-2013, 12:45 PM
Pseudonym's Avatar
M12x1.5 with .509 knurl diameter
I dont think ARP makes a stock length stud, but i put the stock lug nuts and caps on the 2.5 inch studs.
Quick Reply: Wheel Studs
