oil pressure sensor???
Does anyone know if you need to use the oil pressure sensor part number 12573107 in a 70 Chevelle swap? The wiring harness I purchased does not have a connector for it and I'm not sure what to do. Thanks for any help.
Replace it with the proper sensor for your gauge. It has nothing to do with the operation of the ecu. There are adapters from auto meter that go from the metric fitting to 1/8 npt. This is what used to change to the proper sending unit.
