WTB:LS1 Motor
WTB:LS1 Motor
car is a 99FRC Corvette that ate some lifters,damaged the block in several places and is a complete loss.looking to buy a replacement motor for it.located in Tampa.FL.
I have a mildly built LS1 long block for sale. It has CNC heads, GTP 420 cam (.226/.226 - .595/.595 on 112 lsa), dual valve springs and retainers, trick flow push rods, ported oil pump, heavy duty single roller timing chain. It also has an underdrive front pulley. It includes all the valve train and the valve covers.
I just did a top end and bottom end inspection and while I was in there I installed a set of ARP high strength rod bolts and new head gaskets. Everything checks out good, valves are good and the bearings are like new. This came out of a 52K mile 2000 Corvette. $2500 plus the ride.
MrE
MrE
