Help! Car Wont Start!
My 2000 Camaro SS starts up a little rough. Usually i have to give it a little gas while starting it because the engine is stuttering. Once its started everything is fine. But if i start up the car and it stalls while stuttering it refuses to start. This happened to me today in my driveway so i took one of my other cars and jump started it with cables. Even with the cables it did not want to start at all. I finally got it to start up and all was fine.
The idle is definetly a little rougher than i remmember but its set at around 1000-1100 rpms.
What would cause my starting issues? Would a bad O2 sensor also give me trouble? I have no check engine light codes and replaced the battery/alternator recently. I also recently replaced my throttle position sensor because when i would start the car it would automatically rev the engine to red line without pushing or doing anything.
