fuel lines to truck rails
Did a search empty handed. Trying to find some info on how people have their fuel lines ran on fox swaps with the truck intake. I have a turbo setup so the least amount of fuel line I have running around the better. With the truck rails the inlet and return are on the drivers side. Right now all I have is the fox fuel lines. Going to go ahead and get it running til I can afford a full fuel system. Is there a way to swap the truck rails around and put the inlet on the pass side up front and then redo the crossover?
When I was using truck rails I too off the return line and mounted the regulator to the pressure line. Cut the shoulder out of a 5/16" bolt and put it in the return line port on the fuel rail. Worked awsome.
