help setting fuel pressure turbo
I have a small turbo kit on my car and it came with a holley adjustable regulator and 30 lb injectors. I ditched the 30 for 42lb and wanting to know where I should start with on fuel pressure? My buddy was telling me that I swichch over to a boost refrenced, but I see many peopple using these. Max boost will be between 8-10 lbs. Also what plugs are you guys running on theses setups? Motor all stock iron headed motor.
You always run an boost ref regulator when running forced induction! i would run stock pressure with the 42's, but you gave little info on your car, so guess are all anyone can give you...
