220 /228 cam 117 lsa help!!!!!
i have a 00 m6 camaro and i have pacesetters horty headers, ory, ls6 intake ,lid ext..and want to run the 220 /228 cam will this cam yield good power????? if not eps baby cam 222/226 cam makes good power both will smog but i can get the 220/228 cam for around 220 used any advice would help thank you !!!!!
I had a TR 220 and was bad ***. Go with a 224 / 228 and you'll make plenty of power.
The EPS 222/226 113lsa would not be you best choice. First you need a wider split, and second it doesn't have enough negative overlap, it only has -2*, you need at least -4* to pass smog. The 220/228 117lsa cam has -10* overlap so it should easily pass smog with a good tune.
So do you have any more info on the 220/230 cam, like brand, lift or the ICL?
BTW, the cam card would have all this info on it.
Cam specs are Lift- .532" Intake / .555" Exhaust Duration @ .050 220/228 117+4 here are all the specs on the cam its a custom ground cam from comp thanks for the input so far guys !!!!
