T56 crossmember
Old 01-13-2013, 06:00 PM
dropped72ss's Avatar
Default T56 crossmember
Installed a t56 ls2 in my chevelle using edelbrock plates. I want to save cash and reuse the 350 crossmember. Who has modified their crossmember and what is needed? Thanks
Old 01-13-2013, 06:18 PM
bczee's Avatar
I used the original TH350.. just flipped it around as needed to fit and line up, cut the tab off and reweld it back on as needed.. No biggie.. guys have been doing this for a long time.
Here are a few pictures of mine..
BC
Old 01-13-2013, 07:14 PM
Thank you bczee. This is exactly what I was looking for.
Old 02-07-2013, 08:04 PM
Did you use the th350 mount or the t56?
Old 02-07-2013, 11:13 PM
bczee's Avatar
If I recall, I used the TH350, it bolted up with no mod to it.
BC
Old 02-09-2013, 09:27 AM
ChevyMan1989's Avatar
i did the same thing on my 70 chevelle lq4/t56 swap. very simple and cheap way out. and if i remember correctly the muncie and th350 trans mounts are all the same. they bolt right up to the t56.
Quick Reply: T56 crossmember
