Converter Qs for 5.3/76mm turbo/th400 build
What converter would you reccomend for a 76mm turbo 5.3 with a th400? Car estimated race weight it 3400lbs, 2.73 gear with 27in tall tires.
Thanks
Thanks
Need a little more into... How much boost? Cam? Intended usage? For most turbo builds our 258mm is a great choice. Good spool up down low, but very efficient up top. If you can send me an Ask Chris will your full details I can help spec one for you- link in sig...
Chris
Chris
