whats your timing table look like from spool up to max boost on a run?
just curious as to how others are running their combos. what is your timing from spool up to launch to right after the launch when boost is coming in to all the way to max boost that you run? does anyone run damn near NA timing up to 5 psi after the launch or something like that to really light the fire on the launch and the first 330'? thanks guys
