loose drive train? What do you think.
First off I have a 99 Ws6 M6 with a Mcleod RXT aluminum fly tickmaster/slave/fbody tr6060. The issue was minor before the install which is the reason I spent 7k on those parts. I also have a PST d/s with a moser m9 4.10 wave track diff with moser axles. I'm leaning towards something in the diff but I just don't know.
Any how the actual problem, when the throttle is let off at any mph there is this rocking back and forth feel coming from the transmission D/S area sounds like I have a cooler of ice in the car sloshing around.
I've been under the car , had it on lifts checked out everything, everything seemed good to go. I really noticed it after my second strip pass and on the way home I got on it and the car accelerates quick and responsive without any slipping.
So i'm thinking loose motor mounts, pinion angle, or the slave cylinder shim. I'm just hoping you guys can point me in the right direction so I can begin to fix this. Thanks.
