Log manifold design/material question.
Old 01-19-2013, 08:54 PM
Benwb's Avatar
Default Log manifold design/material question.
I'm having to make a passenger side manifold do to room constraints. The plan is to make a log style manifold, I was wondering if mild steel 16g exhaust tubing(2.5/2") along with normal 1 7/8 primary tubing would hold up.This manifold won't be bearing any turbo weight and simply just be connected to a crossover pipe.
Thanks.
Old 01-19-2013, 09:00 PM
jridenour31's Avatar
That will be fine but why the large primaries?
Old 01-19-2013, 11:59 PM
Benwb's Avatar
More of just a number I threw out there to help understand the idea, it'll most likely be 1.5" primary tubes to closer match the stock truck mani on the other side.
Old 01-20-2013, 06:09 AM
MUSTANGBRKR02's Avatar
You could modify a truck manifold to a forward exit. I have one if you would like pics.
Old 01-20-2013, 06:07 PM
Benwb's Avatar
Yah send pics if you can, thanks!
Edit: this is in a first gen rx7 btw
Quick Reply: Log manifold design/material question.
