First turbo build?
First turbo build?
I'm starting my first turbo build do heres my setup plans was just to be a nitrous build but wanna go boost. The motor is a 02 5.3 I re built and put a set of ported and polished 241's cut .030 to put them around 62 or 63cc putting the motor at about stock CR. It has a 228r cam with fast 78mm intake and throttle body with aeromotive rails and 42lb injectors. I traded my nitrous setup for a master power 76mm with a 1.00 ar and divided flange hks blow off valve and looks like eBay waste gate and a air to air intercooler. How does the setup sound and what kind of power should I be able to make with it and what do I need to change.
Thanks Charlie
Thanks Charlie
