Need Help figuring out the year of my F-body Ls1 Harness
Started working on my ls1 harness for my lq4 swap in my nova and have ran into a little
Im using this information for pcm pinouts LT1swap.com and have found a couple places that my harness does not match the pinouts he gives.
Blue connector
not my first LS swap but i modified a truck harness last time so it is my first with the fbody harness.
Blue connector
- Cavity 41 he shows as not used, I have a black wire in it.
- Cavity 47 he shows as not used, I have a gray wire in it.
- Cavity 55 he shows as not used, I have a black or brown wire in it.
- Cavity 4 he shows pink/black, I have a purple wire in it.
- Cavity 7 he shows as not used, I have a red wire in it.
- Cavity 41 he shows as not used, I have a gray wire in it.
- Cavity 44 he shows light green, I dont have a wire in it.
Blue connector
Cavity 41 he shows as not used, I have a black wire in it. EGR, 99-00 only
Cavity 47 he shows as not used, I have a gray wire in it. EGR, 99-00 only
Cavity 55 he shows as not used, I have a black or brown wire in it. EGR 99-00 only
Red connector
Cavity 4 he shows pink/black, I have a purple wire in it. AIR 99-00
Cavity 7 he shows as not used, I have a red wire in it. EGR, 99-00 only
Cavity 41 he shows as not used, I have a gray wire in it. EGR, 99-00 only
Cavity 44 he shows light green, I dont have a wire in it. Reverse Inhibit, M/T only
I'd say you have a 99-00 A/T harness.
Red connector
