T56 shifter assembly!?!?
Old 01-25-2013, 10:13 AM
ls1_driver43's Avatar
Default T56 shifter assembly!?!?
How does the shift go back together I have an idea but should the top be leaning toward the tail and how do the springs go in. Is there an exploded view anywhere of the assembly? It's off an 02 camaro if the shifters are different
Old 01-25-2013, 11:31 AM
calhoon's Avatar
you must have an aftermarket shifter because the stock shifter does not like to be disassembled without bending / damaging it.....it doesn't go back together well.
The Hurst shifter option does come appart... is that wat you have?
Without knowing the shifter you have , its tough to help.
Old 01-25-2013, 02:20 PM
Yes it is the hurst shifter sorry I thought thy all came with that
Quick Reply: T56 shifter assembly!?!?
