Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
HUGE 94 trans am part out
Old 02-02-2013, 05:09 PM
vigalante LT1's Avatar
Default HUGE 94 trans am part out
Category: Accessories
Price: $1
Part Fits: 93-02 Pontiac Firebird
Location (State): FL
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Non-LS Part
Hello, I purchased this car sight unseen being told by the owner it just needed a tune and battery, after getting the car home we found oil in the driver side header so I pulled the intake and found the oil pump drive broken, not going to put anymore $$ in this car so everything has to go!
Complete 6-speed swap, trans. Flywheel, pedals,clutch, ect. $1500.00
Eagle ES 5.7 rods #scr5700bb. Set of 8 $100.00
Speed pro hyperkinetic pistons .030 only 7 of these $50.00
Lt1 block .030 bore, clearanced for 383, brass freeze plugs ect. $300.00
Comp cam cc503, has a small chip on one tooth for the drive $75.00
Heads with comp springs and retainers for the above cam and guide plates, have been gasket matched $275.00
Stock lt1 intake painted red with fuel rail $50.00
30 lb injectors $125.00
Aluminum roller rockers have CQEX stamped on them can't find a lot of info so lets say $100.00
Opti with accel 8 mm wires $35.00
Billet damper hub $30.00
MSD blaster GM coil $25.00
MSD 6al box $75.00
eBay special throttle body with all sensors 58mm $100.00
Canton aluminum lt1 valve covers $125.00
Starter $35.00
Alt. $35.00
Water pump (looks new) $50.00
Radiator (looks new) $50.00
Accessories bracket with AC delete pulley
Stainless steel Long tube headers and y- pipe, not sure of brand with 02 sensors
And clamps $300.00
Complete Trans Am roller hole or will part out, color is green with title.
If you need something that's not listed just drop me a email and I will see if I have it best way to contact me is email or text mnorkavage@gmail.com, 904-838-7062. Thanks for looking mike
Quick Reply: HUGE 94 trans am part out
