1993 Trans Am LT1 A4 - TX - SOLD!!
Year: 1993
Make: Pontiac
Model: Trans Am
Price: $2000
Mileage: 5
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Green
Transmission: Automatic
Drivetrain: Rear Wheel Drive
I have all receipts for all this and the motor was done by my mechanic. Things that still need to be replaced are passenger side window motor, driver side headlight motor, O2 sensor connector, and alternator needs to be checked or pigtail since it's not charging. Tranny started 2/1/13 a small leak. Needs to be jumped by battery to purple (starter wire).. idk if it's missing a ground or what.. But the car does turn on and run.
NEW:
battery
gasket timing cover
distributor (optispark)
timing gear set
fuel pressure regulator
thermostat
head gasket set
spark plugs & spark plug wires
brake pads & drums
bosch water pump
water pump coupling & seal
brake line
serpentine belt
tail light bulbs
OBD1 cable & software
USED:
cutout (manual)
ls1 tail light harness
alternator connector
temperature sensor connector
Ram Air Hood (OEM)
Fuel pump
shifter cable
oil dipstick & cap
front bumper
side skirts (1 side has small damage to it)
LT1 heads
radiator repair
Price Drop: $2,800 to $2,000 FIRM
If you are interested let me know, thanks. Asking price $2,000 FIRM
Call or Text 10AM - 9PM Thanks! (956) 246-9425 Louis
