c5 p1sc the same as a p1sc for an f-body?
Old 02-05-2013, 06:11 PM
sweet99ss's Avatar
Default c5 p1sc the same as a p1sc for an f-body?
Wanting to know if a p1sc from a c5 corvette is the same exact procharger as the one in the f-body kit? I know they are both reverse rotation, but Idk if they are interchangeable?
Old 02-05-2013, 06:39 PM
LS1Tech Sponsor
Slowhawk's Avatar
yes it is the same
Old 02-05-2013, 07:34 PM
sweet99ss's Avatar
Originally Posted by Slowhawk
yes it is the same
Cool so exactly the same no differences? same size and all?
Old 10-27-2013, 02:48 PM
white2kbird's Avatar
Bump,,, what modifications are needed if i buy a p1sc kit from a c5 for my 2000 t/a? thanks
Old 10-27-2013, 06:01 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
You want to make sure the oil slinger is always at the bottom of the case. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 10-27-2013, 06:08 PM
Thanks Bob, so other than the clocking of the casing, would the same j bracket and ic piping work on both applications?
Old 10-27-2013, 06:17 PM
LS1Tech Sponsor
You can use the head unit, possibly the blower pulley and the bypass valve. If you go six rib you'll need the 98-02 F Body bracket assembly http://shop.brutespeed.com/ATI-3GJBB...I-3GJBB-01.htm, crank pulley http://shop.brutespeed.com/ATI-DC017...DC017A-006.htm, crank bolt http://shop.brutespeed.com/ATI-DC017...DC017A-001.htm, inlet assembly http://shop.brutespeed.com/ATI-3GJAI...I-3GJAI-01.htm, air filter http://shop.brutespeed.com/ATI-AF056...AF056I-009.htm, intercooler assembly http://shop.brutespeed.com/ATI-98-02...r-Assembly.htm or http://shop.brutespeed.com/ATI-1GJ11...-1GJ115-IC.htm, blower belt http://shop.brutespeed.com/ATI-DPxxx...TI-DB-Belt.htm, horn bracket http://shop.brutespeed.com/ATI-MB008...MB008I-001.htm, air pump/cruise control bracket http://shop.brutespeed.com/ATI-3GJAP...AB022I-002.htm, fan http://shop.brutespeed.com/ATI-MF006...I-MF006I-0.htm, sheetmetal hold down http://shop.brutespeed.com/ATI-MF006...MF006A-003.htm, upper/lower fan shroud http://shop.brutespeed.com/ATI-MF006...MF006A-024.htm, fuel pump http://shop.brutespeed.com/Walbro-GS...bro-GSS340.htm, injectors http://shop.brutespeed.com/Siemens-1...ens-107961.htm and a tune.
If you want to see a copy of the installation instructions, send me an e-mail to brutespeed@gmail.com asking for them. Bob
__________________
Quick Reply: c5 p1sc the same as a p1sc for an f-body?
