Milling 243 heads on a 5.3 LH6 to increase CR
Old 02-05-2013, 09:26 PM
addictedtotrack's Avatar
Default Milling 243 heads on a 5.3 LH6 to increase CR
I have been searching and haven't found a clear answer yet. Does anyone know how much I could successfully mill off of the 243 heads on a LH6? I have a Z06 cam and a set of stock MLS gaskets. I believe the stock CR is 9.9 or 10 and would like to get it into the 10.5-10.7 range. Wasn't sure if I would run into any issues milling what is needed to get into that range. Thanks!
Old 02-05-2013, 10:38 PM
oscs's Avatar
measure vtp clearence and take off as much as you can.. unless your looking for an exact number.
Old 04-28-2013, 06:56 AM
camarozz383's Avatar
Any new info? I'm getting into the same thing!
Quick Reply: Milling 243 heads on a 5.3 LH6 to increase CR
