Truck harness in 96Z28
My 96Z28 is already a running LS1/4L60E swap. So i don't want to hear just use a F-Body harness. I already have one. My question is could I modify a factory LS/4L80E harness to work in my car rather than buy an adapter harness and run a different trans segment. Id have to use the truck pcm Im guessing. Any drawbacks to that? Im looking into a 6.0 4L80E drop out and want to try to use factory truck harness. Im going turbo so thats the reason for the swap. Thanks!
LS1Tech Sponsor
You could do that, but everything would obviously be routed differently. It would be easier for you to just add in the input speed sensor and repin your 4l60e connector. Then do the segment swap. If you need the wiring info on how to modify your existing harness for the 80e just let me know. Its super simple.
That will be much less work and money.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
LS1Tech Sponsor
As stated above the repin of the 4L80E isnt too bad. Plus if you are going with a car or aftermarket intake, all the connector locations are going to be consistent with the F-Body not the truck. Stick with the Camaro harness.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
