Fox In-tank pump vs A1000 for LQ4 turbo
Old 02-07-2013, 05:23 PM
zapp109's Avatar
Default Fox In-tank pump vs A1000 for LQ4 turbo
I bought my car with a intank 255 pump and it already has braided lines from the tank to engine bay. I have and older A1000 pump with filters, i was going to sump the tank and put that on but should i look into some intank pumps instead? Its a 95% street car and aiming for 1000HP with meth. What do you think?
Old 02-07-2013, 05:27 PM
stangtrader's Avatar
Id sump it and run a big external for that power level. from my research its too much work to try and make twin intanks fit.
Old 02-07-2013, 05:38 PM
zapp109's Avatar
yea i guess that was really what i was wondering can it be done or is there a kit...
Old 02-07-2013, 05:47 PM
From what ive seen the bucket in the tank is too small so youd have to cut open the tank modify it then weld it back up.i thought of using a sump but mounting two intanks in the sump so its quiet.a member on here did something similar with a fuel cell
Old 02-07-2013, 06:39 PM
Sarg's Avatar
What fuel do you plan on running?
Old 02-07-2013, 06:48 PM
zapp109's Avatar
93 octane with meth
Old 02-08-2013, 12:17 AM
Speedy911's Avatar
I'd do 2 Bosch Pumps or 2 Walbro 400s, plenty of fuel
Old 02-08-2013, 12:53 AM
redss82's Avatar
could always run that pump to a surge tank then a big external or two from it
Old 02-08-2013, 06:39 AM
zapp109's Avatar
I found a bit of a different setup check out this, instead of running a sump setup
http://www.theturboforums.com/thread...nd-pickup-tube
Old 02-08-2013, 06:51 AM
1bad03snake's Avatar
I'm running an A1000 and sump
Quick Reply: Fox In-tank pump vs A1000 for LQ4 turbo
