Ls 5.3 truck cruise control
Old 02-08-2013, 04:34 PM
russellgmefi's Avatar
Default Ls 5.3 truck cruise control
Running a 2008 5.3 out of a Silverado. I am trying to make cruise control work. I am using a BCM and the stock cruise control steering wheel switch pod. The cruise worked fine the first time each day. Once you drive it and then kill it, the cruise will no longer work. It won't work again that day. The next day or so it will work the first time you drive it only. Help Dennis
Old 02-23-2013, 11:32 AM
J_O_E's Avatar
Sounds like it heats up and switches off. Does it have to sit a full day?
Old 02-24-2013, 03:05 PM
62n62's Avatar
Default cruise
it will work all day as long as you dont cycle the key
Old 03-16-2013, 06:18 PM
62n62's Avatar
Default cruse control
found a way to put c/c on any drive by wire ls motor pm me for details thanks mike
Quick Reply: Ls 5.3 truck cruise control
