Will this cam work?
Old 02-10-2013, 08:32 PM
WindWalker's Avatar
Default Will this cam work?
Motor specs: LS6 block and intake, 9.1 CR, 6.0 CNC'd heads, 1.7 rollers, 4 in. stroker crank, T-70 turbo trim unknown, .98 AR. 1.75 in. collectors, M6, 3.50 rearend, 17 in. tires. Will be a street car. The cam specs are lift .614/.610, duration 227/223 @.050, ICL 112.0 lope separation 115.0, IVO 25 BTDC, IVC 71 ATDC, EVO 73 BBDC, EVC 19 ATDC. I want to rev to 7K. Not knowing much about cams, this sounds a little too big for the T70. Any thoughts? Thanks.
Quick Reply: Will this cam work?
