General LSX Automobile Discussion Non-technical LSX related topics.
does this sound like knock?
Old 02-10-2013, 09:57 PM
greedygenius's Avatar
Default does this sound like knock?
it only does it at idle goes away at any rpm while driving. just curious what you guys think?
Old 02-10-2013, 10:17 PM
nobody?
Old 02-10-2013, 10:24 PM
03EBZ06's Avatar
my first thought is to check lifters, valve springs, pushrods, rocker arm bolts, check clearances.
take the serpentine belt and blower belt off and see what happens also to localize noise to engine or spinning accessories.
Old 02-10-2013, 10:29 PM
sounds like a good idea...does the whole unplugging plug wires 1 at a time thing work?
Old 02-10-2013, 10:39 PM
03EBZ06's Avatar
might be worth a try. You go from having huge compression under fuel/air explosion to having on 185-200psi static pressure in there.
speaking of compression, I would be checking static also in case of cracked piston.
Old 02-10-2013, 10:57 PM
cj92345's Avatar
Almost sounds like exhaust leak
Old 02-11-2013, 12:11 AM
the exhaust thing would be nice lol. cant say the same for the cracked piston.It also breaks up under WOT at 5500-6000 but is fine if i ease into it.not sure if both problems are related.Guess ill try to look for an exhaust leak tomorrow and try to change plugs and wires with a tighter gap. hoping for exhaust leak and just blowing the spark out.
Quick Reply: does this sound like knock?
