F/S Forgeline 18" SOP3 3-piece wheels (Pics)
Category: Wheels & Tires
Price: $3500
Part Fits: Corvette
Location (State): TX
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
The color is gun medal grey with light metallic flake and the lips are polished. These wheels are made to fit a big brake system and fit perfectly over a C6 ZO6 brake conversion. Each wheel is built with forged 6061-T6 aluminum centers, and 6061-T6 spun rim halves.
Extras:
*Titanium aircraft-grade ARP fasteners which remove close to a pound of weight at the most outer part of the wheel which greatly reduces inertia. This is a $480 option.
*Pocked lightening. Machined pockets cut into the mounting pad, in between the lug bolt openings. This eliminates excess material resulting in up to a 1 pound weight reduction per wheel. I don't remember how much this cost.
*Diamond cut finish. The center is actually machined, powder coated the base color, placed back in the CNC machine to re-cut the chamfer, and then a clear coat is placed over the entire center for protection. Facets and lines are left in the machining, which reflects the light brilliantly. This is a $800 option.
Front wheels are 18/9.5
Rear wheels are 18/11
Front tires are Nitto 555
265/35ZR18 UTQG Treadwear: 300
Rear tires are Nitto 555 RII
305/35ZR18 UTQG Treadwear: 100
Brand new
Front wheel on the car
Rear wheel on the car
Side view
Side view
