Question about coolant temps?
Hi guys, I have a 2002 Trans Am that I'm asking this question about. I hadn't actually paid attention to it before until a couple of days ago. From the time I start the car, in about I'd say 5-10 minutes while on, idle or running the car will go from the bottom temp on the coolant reader and then gradually halfway. I don't know if that's normal?
I mean, today was only in the 30s outside, wasn't even hot and the needle still went halfway. I haven't noticed it get any higher, I'll have to monitor it more.
Anyway, is there a problem and what can I tell my mechanic to check? Sorry, I don't know crap about fixing my own car so mechanic it is. Just want to get the heads up on what could be wrong that way I can get straight to the point at the mechanics. Thanks in advance!
Seems pretty normal.. If you're really concerned, bleed the system. Remember, we have a "lazy" coolant gauge, as in the needle reads right around 210* unless it starts to overheat
Also, so I won't bother you guys with another form post, my car feels slugish when accelerating. Recently put the Volant cold air intake that I had on my 98 T/A(the 2002 T/A still felt that way before I changed it just to note) and I also changed the car oil and that helped it but at times it still feels like that. If you could please list some of the possibilities of why?
I remember my 98 T/A feeling much more smoother/responsive when accelerating.
I'm not as mechanically inclined or experienced as some people here but I had a similar issue when I removed my TB and lid/bellows. Turned out my bellows were loose and collapsed during my drive and had literally no air flow. Or it could be a misfire. I would check plugs and wires as well.
