Hypertech questions
Old 02-14-2013, 10:38 PM
DirtyBirdMKE's Avatar
Default Hypertech questions
I have a 98 TA ws6. When i bought the car it came with a Hypertech Power Programer....... i have no idea how to use this thing. The website doesnt have a downloadable manual for it. Anyone have a link?
also, im throwing a CEL im almost positive is a O2 sensor, does the programmer scan codes too???
Old 02-15-2013, 01:19 PM
Hypertech's Avatar
The Programmer is very easy to use, when you hook the unit up to the diagnostic port press Y after that it will walk you through each question and you answer yes or no except the rpm limiter and shift points which you only change if you are at the race track to make fine tune adjustments. The programmer does pull read and clear codes. Pm me with your mailing info and I will find a manual and send it to you.
Old 02-15-2013, 04:23 PM
pm sent... thanks alot
Quick Reply: Hypertech questions
