Summit Line Lock Q's ?
I am a total newb when it comes to brakes. Can someone tell me which part I need from summit as far as their line lock kits go? Also will it come with everything I need or will I need to obtain anything else?
2000 Camaro SS
2000 Camaro SS
The part number for the lines they suggest are HUU-5671510. Im guessing you got the line lock PN SUM-76000? They're Hurst lines with almost all the fittings for $31.95. Like I sayed before though, you can probably make your lines and save a few $$. This is everything you need though. But you will have to bend your own lines. So you may need that unless you take some washers and a vice grip and clamp them to a table and bend them that way. Im sure if you start finding people on here near you, they can probably help with tools and better knowledge.
