L92 LS3 stroker build (Need Advice)
Hi there, I recently purchased a l92 out of an 07 Escalade with 40,000 miles. Anyways I plan on using this Eagle 4" stroke crank and 6.125 rods that I had for my ls1 build up. It has the 24x reluctor wheel and I already have a computer out of a 98 z28 6 speed car. I am hoping to use them since I already have them. I recently got my cam from comp it is 235/251 @ .050 .620/.623 with a 114 lsa. I plan on porting the heads and installing better valves. Also I want to run the stock ls3 intake. I am wondering what throttle body size and injector size do I need to support approx. 600 hp ? I plan on putting this in my 69 Camaro with my rpm stage 5 t-56. I am going to mini tub this car and was also wondering if anybody could tell me the best route to go on the efi gas tank? I am not really wanting to spend 1300-1500 on a tank assembly. Any help will be Greatly appreciated. Thanks, MIke
Injectors - 48lbs will leave you some wiggle room
The computer and reluctor are fine.
Throttle body 90 or 92 , contrary to what people think the larger tb isnt gonns offer any hp unless its a restriction and it isnt until youre making big power.
At least consider having the intake ported or spring for a fast.
T56 shifter 69 camaro
I also need some input on the best shifter to use in my 69 camaro LS3/T56 .Also I just received my 3 bolt cam and was wondering how to make it work with my Painless 98 LS1 harness. Thanks, Mike
