69 camaro ls3 a/c bracket location.
Hello, I was wondering if anyone had a solved issue with a ls3 and a ctsv accessory drive. I have vintage air and would like to keep the sanden compressor low, but I dont have too. Is there a bracket or Mod I can do, so I can keep the location or is it better have gotten the corvette accessory drive. Also my alternator which is low also barely fits and is very close to the frame. Is there a smaller alternator that would give me better room. Thanks in advance for the valuable information. Jason
Typically people will cut a clearance notch and weld in plate in the crossmember if there is a clearence problem with low mount alternators or compressors. The only off low mount sanden compressor mount is the Alan grove, but it does not look like he offers one to match the CTS-V/ Corvette spacing. There are several companies that offer high mount Sanden compressor brackets, Kwik, Holley, Dirty Dingo are the ones that come to mind.
You can also look at the official X-body swap FAQ in this forum, since the 67-69 Camaro and 68-74 nova share essentially the same subframe and suspension the accessory fitment is the same.
Hey MisterD. Not sure why you dug up this old thread to ask about the alternator, but to answer your question the 4th and 5th gen Camaro alternator brackets are different. I suspect the 5th gen Camaro alternator sticks out further because the upper mounting hole is moved outboard compared to the 4th gen. However I don't know if the alternator hole is also moved outboard to compensate.
