6.0L oil question.
Old 02-23-2013, 09:25 PM
Powe's Avatar
Default 6.0L oil question.
Ok so I have some amateur questions. I have a LY 6.0L with an F body oil pan in my 67 Nova. Two part question.
1) I'm looking to use a Lokar dip stick but which one do I use?
2) How many qts of oil with the LY and F body oil pan?
Jason
Old 02-23-2013, 09:39 PM
LS1TOYOTA's Avatar
Jason
Use a LS1 f body dip stick.
Oil capacity for a LS1 f body, ~5.5 qts
Old 02-23-2013, 09:52 PM
Powe's Avatar
Wasn't sure if the capacity would be different b/c of the 6.0L truck engine?
Old 02-23-2013, 10:07 PM
LS1TOYOTA's Avatar
Capacity is based on what the pan holds.
Old 02-23-2013, 10:20 PM
Powe's Avatar
perfect.. thx man.
Why no Lokar Dip stick?
Old 02-23-2013, 11:31 PM
i r teh noobz's Avatar
Probably way cheaper to get the F-body stick.
My 5.3 with the F-body pan takes 6qts.
Old 02-24-2013, 06:01 AM
LS1Tech Sponsor
psiconversion's Avatar
I believe 5.5 qts. is the capacity without filter.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 02-24-2013, 09:55 AM
67Skylark's Avatar
lokar ED-5008, I have it installed on a LY6 with the F-body pan, would have used the factory one but didnt know better at the time, purchased with pan from S&P, you have to cut the bottom of the tube off maybe one inch max as it hits the windage tray. If you pruchase cut 1/8 inch below the step down from the oring boss. I will attach picture that may explane better.
Attached Thumbnails 6.0L oil question.-dscf2088.jpg   6.0L oil question.-dscf2086.jpg   6.0L oil question.-dscf2083.jpg
Quick Reply: 6.0L oil question.
