Which transmission? On a tight budget, CHEAP is GOOD
Old 02-24-2013, 12:44 AM
THEhomelessONE's Avatar
Default Which transmission? On a tight budget, CHEAP is GOOD
Trying to piece everything together for a total cost. It's going to be mated to an LR4 4.8 and dropped into an E30 convertible, so won't have much TQ behind it but could see RPM in the 7-7.5k range. Cheapest I could find a t56 magnum or tr6060 was around 2000-3000, 5 speed is okay as well, just want something cheap for now, thanks!
Old 02-24-2013, 06:47 AM
murphinator's Avatar
my wife ran a little e30 for almost 15 years , would have kept it if I knew about ls swaps then lol
Old 02-24-2013, 10:55 AM
They're awesome little cars, mine came with an LSD diff and it makes even a 4 cylinder fun lol Pick up another, swap kits for e30's go for around 1500.
Old 02-25-2013, 06:46 AM
garys 68's Avatar
LS1Tech 10 Year
What are you going to use the car for? Do you need an OD trans? Cheapest OD trans might be a used V8 f body T5, but not terribly strong. A 4 speed Muncie/T10 can be found cheap, but no OD.
Old 02-25-2013, 05:41 PM
It's going to be my DD, yeah I was looking into the T5's, but I'll be better off waiting for a good deal on a t56, everything LS related is expensive in CA, thanks guys!
Quick Reply: Which transmission? On a tight budget, CHEAP is GOOD
