Header Hang-down- 69 Camaro- Dougs vs Dynatech
Does anyone have a picture of how low the collectors hang on either Doug's or Dynatech headers on a 69 Camaro? I like the clearance that the Dynatech header creates at the steering box by bringing the 2nd tube up and over at the top, but the 4-bolt collector flange just seems like it would hang quite a bit lower than the slip-on collector on the Doug's headers, since it's got the flange around it.
Whatever answer someone gives you, be sure that you clarify which frame stands were used for the installation since any header that was prototyped on a car with tall frame stands will hang lower than intended with the short frame stands.
