1995 z28 side window scratches cant find part number
i have been noticing scratches on the side glass. Upon inspection i found that the window stabilizer bracket seems to be in good condition, but the long felt pads on the outer side of the window are all rusty and worn. does anyone know the correct name and part number for what i am describing?
thanks
thanks
well they are in good condition its the ones on the outside of the window that connect to the outer window felts and are long bars. would you happen to have the part number and name for these?
thanks
thanks
I need to replace those as well. I jotted down the part numbers when shoebox last posted them:
Inside sealing strips
10257988 (two required per window, four total)
Outside sealing strips
10284223 (driver's side)
10284222 (passenger side)
I gather that the outside ones are tricky to replace.
