Setup thoughts..
Setup thoughts..
alright guys, last time I posted up, I was building a Turbo 408 97 T/A, but since then have sold the car, and the block, and bought an 04 Corvette, now I'm looking into putting a blower on it with a simple setup and would like some input from guys with a little more knowledge than me. So far here's what I'm thinking
Stock-ish LS1
A&A T-Trim, or Procharger P-1SC
small "stealth" type blower cam
317 heads with springs and retainers...
the 317's are my main question, since I already have a set of un-molested 317's sitting at my disposal be best to use those for the lower compression or just use the heads already on the motor?
Stock-ish LS1
Maybe look into the tick stage 1 blower cam or I see a lot of people like the ls9 cam for a more mild setup
thanks for the input, the 317's were my biggest question, since I've seen a lot of mixed opinions of putting them stock cube LS1's.. just figured it might be better to run the 317s since they seem to drop the compression....not looking to make the big power street car, just keep it close to the 600hp mark until I can forge the bottom end.
alright, I've made up my mind, I'm just going to go with the Hinson single setup with a 76mm, on a stock cube 5.7 LS1, with some 317's, and blower cam.. keep it semi low boost until I get around to getting Forged rods and some new pistons... should be interesting when I get around to it in a few months
