pcm tune for pin 34 questions 4l60
Old 03-05-2013, 09:34 PM
Z284U2TRY's Avatar
Default pcm tune for pin 34 questions 4l60
The pcm is programed for pin 34 to control the shifting of a 4l60.
How do I set up the pin 34 to control the trans?
The harness has the trans range sensor still in it. I was going to remove this and only keep the white pin 34.
Old 03-05-2013, 10:03 PM
LS1Tech Sponsor
BP Automotive's Avatar
Cavity 34 is simply a ground signal to let the pcm know if you are in park or neutral.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 03-06-2013, 09:02 AM
Z284U2TRY's Avatar
Are you saying pin 34 just goes to ground in park/neutral and is open in drive?
I know pin 33 will be on a brake pedal switch with constant 12v when brake is not in use and 12v broken when brake applied.
Old 03-06-2013, 12:06 PM
LS1Tech Sponsor
Both of these are right on the money!
__________________
1-888-467-4491
Quick Reply: pcm tune for pin 34 questions 4l60
