60lbs injectors fs
60lbs injectors fs
I have these 60lbs injectors forsell. Thought I needed these when I did my motor but dont. I paid 300 looking for
250shipped
These are ev1 connectors but they come with plug and play harness. So these will work with our cars
Specifications:
Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
Gain: 0.11ms/mg
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 600KPa
Connector: Bosch EV1
Series: DEKA 4 ( DEKA IV )
Orifice Type: Multi-orifice
Spray Pattern: 30 Degree Spray Cone
Factory fitted with Viton upper and lower o-rings
48mm end to end
250shipped
Specifications:
Gain: 0.11ms/mg
Offset: 0.055ms
48mm end to end
