Clutch lost pressure just but sitting in the garage
So my car started grinding when going between almost all gears up until 5th starting 2 months ago. Clutch felt fine, just would grind. As soon as I started noticing it, I stopped driving it and had it sitting in my garage ever since not being driven. I go to start my car today and notice that my clutch has 90% play and feels like only the last 10% is moving the clutch but I can not get it into any gear at all.
What would cause this?
Also I did not notice any leaks in the engine bay and the carpet under my car is still white.
The big reservoir you checked sounds like your "brakes" reservoir. The smaller one white one is the clutch reservoir which sounds empty which you prob have a leak. Check under car by bellhousing or by clutch pedal under dash against the firewall for leak.
Yes I think that would be a good idea to take it to a mechanic you trust, the clutch fluid reservoir holds brake fluid which is clear and you said you have white carpet under your car, which is why the leak isn't visibly apparent, but If you look at your bellhousing where it mates to the engine oil pan you will probably see signs of where the clutch (brake) fluid has been leaking out.
