lt1 cutting out or studders from 3800 to 6000
Old 03-12-2013, 07:29 PM
94blackz's Avatar
Default lt1 cutting out or studders from 3800 to 6000
I hope this is in the righ place this time.if not please help.
I have a 94 lt1m6 camaro.as the title states it has began to cutout and buck above 3800rpms.it only does it in 3rd gear and above.it still pulls hard just cuts out.it pulls good between cutting out.does it at half throttle aswell under a pull.fuel pump and filter are fairly fresh.no codes im stumped.i would really aperciate any advice before i start throwi g money at the wrong parts.thank you for any help
Old 03-12-2013, 07:44 PM
nascarnate326's Avatar
Is your mass air flow clean? You can buy special cleaner at the parts store.
Does it rev freely to 5500 rpm when in neutral?
Old 03-13-2013, 11:15 AM
94blackz's Avatar
Yeah it reves great.just does it when im beatin it after it gets up around 3800 in third.even cruisin down the road at 70 and grab 4th it starts doing it
Old 03-13-2013, 04:03 PM
96LS1zee's Avatar
Could possibly be an ignition problem, how are your plugs and wires? Do you have a scan tool?
Old 03-13-2013, 06:12 PM
11SECSS's Avatar
Did this happen all of a sudden or after you had done something to the car...i"ll take a guess and say it sounds like the opti is going bad or the coil.
Old 03-13-2013, 07:38 PM
94blackz's Avatar
Happend all at once im gonna throw plugs wires cap and rotor on it this weekend and a coil if that dont fix it. ill change the opti when i do my le h/c swap in a couple weeks when my taxes get here.
Quick Reply: lt1 cutting out or studders from 3800 to 6000
