Does Anyone Have the Install Instructions For the HSW 78mm Sudden Impact Kit
Like the title says I need the install instructions for the kit. I lost the instructions during my moving process. I looked online for it and have not had any luck finding it. If you have a copy or a link please let me know. Thanks for the help.
Ls1tech & Truck Sponsor
Is there anything in particular that you are need help with?
You could use our instructions on how to wire everything but the jetting would be different than ours so don't use our jetting.
If you would like you can give me a call and i can walk you through the install to help you make sure you have everything setup correctly.
Trey
Trey
Hi Trey, I just bought atrain59's nitrous kit and he was trying to locate the instructions for me. If u have a instructions you can send, that would be great. I've also been reading through the wiring sticky to try and get things figured out.
