How much fuel????
Old 03-18-2013, 12:14 AM
Boostang98's Avatar
Default How much fuel????
Starting our first 5.3 swap into 98 v6 mustang. Was just wondering how much fuel we need to make say 700 rwhp? Will be going with a TC78 and are trying to decide 60 or 80 lbs injectors. The car currently has a 310 lph Focus pump and are planning to add a second pump. Are the stock fuel lines going to be adequate?
Old 03-18-2013, 12:16 AM
itsslow98's Avatar
What type of fuel? Pump gas or E85? I would do 80s either way. I dont think stock lines are gonna handle that kind of power in a v6 car.
Old 03-18-2013, 12:19 AM
Boostang98's Avatar
My thought is the the lines are the same size in 03-04 Cobra. This will be a pump gas setup because there is only one station with E85 within miles. I also have a water/meth kit to add to the mix if needed, but would rather take a "set it and forget it" approach to the tune. I also have no issue with running a 3/8 feed line and using the factory feed for a return if need be.
Quick Reply: How much fuel????
